Lens Configuration For GH4 On GB603 Gimbal
Anyone know what the stock lens configuration is for using the GH4 when mounted in the GB603 as guess it will be balanced and set for a particular lens ??
It's balanced for the Olympus 12mm. At the moment I've only flown with that lens. However I've also tried (not flown):
- 15mm: Doesn't fit
- 25mm: Doesn't fit
- 45mm: FITS (Will try flying it in the next week or so)
I've also been told that the 20mm fits too.
- 15mm: Doesn't fit
- 25mm: Doesn't fit
We have used the 45mm and all you need to do is simply trim the aircraft out, which in pilot speak means popping in additional aileron (down in this case to counteract the off balance weight) or you can let the H920 level itself out for you. Landing or taking off is where it's most noticeable.
mining_drones
