Lost control of camera
I would re-sync the camera and perform a gimbal calibration. Have you removed the camera from the "H"? If so, remove and re-seat it. If not, it won't hurt. If that doesn't help, I would contact support.
I'd start with a camera removal and re-install, rebind, and then calibrate the gimbal. I've had that happen where all that was needed was a simple shut down and re-start of the system, but re-calibrated to be on the safe side.
I will give this a try tomorrow. Thanks
dharminder
