Micro SD problem. What Micro SD buy?
Reactions: arruntus
Thanks to the Black Friday week I was able to pick up a valid card for the H520 cameras and cheap. They are 64GB and I would have liked them to be 128GB but there is.
SanDisk Extreme PRO 64 GB microSDXC UHS-I
I've tried both of them and without doing anything, put them in the camera and run the first time. So it should have been with the other card, too. We are on the move :D
Reactions: WheelsUp
I use the SanDisk 64gb Extreme Plus, used it at 4K 60fps no issues so far.
It's the option I was going to buy. Then I read the specs and it says that at most it records at 60Mb. Theoretically 90Mb is required as a minimum, so I opted for the pro version.
Well it says right on the package 100mbps, at least mine did.
Sorry, you're right, I was mistaken for Samsung's models.
The Extreme Plus has a read/write speed of 100/90MB/sec.
Extreme Pro has a read/write speed of 275/100MB/s
With the Samsung model problem choose to change brand.
Axel66
