MicroSD card refuses to go out the E90
I was using Samsung EVO plus 32gb cards before and had no problems.
i bought a better card the sandisk sdxc extreme 64gb 90mb/s v30.Today i used it for the first time in my E90, but i cannot delodge it from teh camera. Whe i push on the micro SD card to go out of the reader it refuses to go out.
Anyone has an idea and which cards are you using that gives no problem.
I can of course buy a Samsung EVO plus 64gb but am i shure the same thing will not happen also.
Marnix
I've read where others have put the card along side the sleeve and it gets lodged. If it goes down but doesn't come out then the latch is probably not working or broken.
It's happened to me too many times, especially at the beginning. I got her out once with a pair of pliers. It hasn't happened to me in a while. Be careful not to force anything to keep it working. It's a quality problem.
Good luck :confused:
the micro usb connector on the camera is used for what ?
Is it not possible to use a usb cable to download the recordings
Marnix
Have you tried to use a pair of sharp nose tweezers? Push down and then pull up.
nvjfirut
