missing tlog files on H850
Hello,
I have a question about the storage of tlog files that should be stored on the controller.
I flew two flights and used two sets of batteries for them. However, I can only find the tlog file of the first battery set on the controller. There is another very small tlog file with two minutes of data, as I briefly switched the drone on and off. But the second flight, about 40 minutes of flight time, is not there.
Do you have any idea why this could be? Is the log possibly only saved if the drone itself contains an SD card? I can't explain the connection, but that would be the only thing that was different on the second flight compared to the first. However, the ulog files from the drone itself are all there, including those from the flights after the battery change, but the tlog cannot be found.
I am thankful for any help!
Frida Gold
