Need a pic of the update connector
When I bought my q used, it came with a missing update connector in the body. I have just the 4 wires hanging, 3 with pins. I need to repair this but can’t find a pic of the connector to see the color layout. Can someone please post a pic of that connector? Once repaired I can finally hook up to the GUI. Thanks.
Yeeeees! Thank you. Would you happen to have a pic of the connector plugged into the programmer lead? I think I can work with this. Thanks!
I was adding it to the drawing just now. You get to be the first to use it. Note the PC side only has three wires. It does not use the BLACK wire from the drone side.
Note also the connector is drawn with the "plain side" facing you.
Edited 2019/06/27 - Edited drawing to provide consistent connector orientation and a common legend. Bolded text above was edited to correct inaccurate color of missing wire, and description of connector position.
Dvca441772
