- Joined
- Oct 27, 2017
- Messages
- 424
- Reaction score
- 376
The wait is over. Any info on the bug fixes in the release?New update out today Build809 dated 20190131
Now gives up 2x, 4x, 8x, digital zoom.
To use this feature pinch the screen and move your fingers away from each other to Zoom in and pinch closer together to zoom back out.
Found it: Add new feature: Digal zoom that support 2X, 4X, 8X. Optimized function of identifying large capacity SD card. Upgrade the version to 1.1.03The wait is over. Any info on the bug fixes in the release?
Sent from my CLT-L29 using YuneecPilots Drone Forum mobile app
Go into the secret menu DCH and change settings to Global OTA and it will be thereI'm not seeing this update available. It must only be a available across the pond.
Well well well, would you lookie there!
Thanks Peggy!
But just one question remains....
How many new tricks is this old dog expected to learn?
What kind of treats would you like to learn new tricks?Well well well, would you lookie there!
Thanks Peggy!
U
Butt, it introduced a tilt buzz at full up and 45° down
Full up and 45 down, is that the camera position or the relative tilt of the aircraft itself?
Somehow I think you will be fine if you didn't have buzz before. I never had the buzz problem before I updated to Build 784 and the initial calibrations done with the 40.5mm filter and counter weight. Now that buzz problem is traded for a different one!FWIW I just tested mine and I did not notice any issues through the full range of motion of the camera. I hope to fly tomorrow. We'll see how it goes.
