Weather finally got up to mid-teens with mild wind... previously performed all Firmware Updates, successful bond RC & CGO4, the ECU & Gimbal calibrations inside and warm. Couldn’t get a good compas cali in driveway, so tried an open field... in 3ft snow & -16 Windchill. After 3 failed attempts, figured it was maybe the 60 second time limit and not the Cali reading causing failure so spun the H a bit faster and got the melody and positive lights.
Returned to home to warm hands & H, then tried 1st flight Hover at end of driveway with 17 Sats indicated available (Normally able to fly all my DJI models from drive without issues). The H started nicely, spun up the props and lifted smooth. Had a mild drift with wind to the West (left) but figured I’d explore that later on a warm day. Today was just to verify flight operation.
Took the H up & down, Lf & Rt, full 360’s, etc. Took it up to 50’ to test landing gear. No-Go... Rt leg appeared to try, but left leg solid. Cycled the landing Sw without success. Is there a way to test landing gear on bench?
Hovered down to land... skids would touch then slightly begin struggle & bounce and initiate a tip over to Left. Twice I aborted and lifted back up... verified all switches off: Landing gear and Obstacle Avoidance. Flight Sw Middle for angle mode / purple light.
On several proceeding landing attempts, pressed and was holding Kill switch... but before killing, started to lean to left and I aborted before prop strike.
Each attempt, would fight to get the H to touch down... then would start leaning.
Tried holding kill switch while near ground, just touched down when motors stopped... was in a lean with Rt skid light... close to tip over.
Restarted RC and H... lift off smooth, landing touched down smooth... then suddenly lifted off. Brought it back down, and same difficulties. Tried a kill Switch while hold Lf stick down... in last few seconds, tipped over and prop strike on two props... causing motor stall.
Questions: Is the cold causing poor landing behavior, did attempting to cycle landing gear make it appear as gear up? Poor landing behavior is new to me, normally my experience is when near ground or at touch down, smooth power down.
Any suggestions would be helpful,
