I don't have a breeze so I can't give you any specific differences between that and a Typhoon H other than to say it is a totally different type of system. Also, there is so much discussion about DJI vs Yuneec that I won't get into that either - you can search and find a lot about the reason a lot of us that are now flying Yuneec (I used to fly and still have an older Phantom). Rather I would just point out that the Typhoon H has had nearly all the bugs ironed out over it's 2 plus year existence and is a solid aircraft. While some have problems with the aircraft;
most of those problems are operator induced from not be as familiar with the H as they should be. The Typhoon has a good 12 MP camera and can shoot DNGs, so if that suits your photography requirements you'll be good there. From an economical point of view the Typhoon is a great value as you pointed out. I would argue that the form factor of the controller, coupled with the retractable gear, 360 degree rotating camera, and one of the best 3 axis gimbals on a consumer level drone; make the Typhoon H a superb entry level video machine as well.
If there are any minuses it might be that CS is not as good as it was years ago, but if you take your time, learn the aircraft and stay within your limits, you may never need customer support. The Typhoon manual is very basic but this forum and the wealth of knowledge that exists here, more than makes up for a crappy manual. Also the Typhoon is not very forgiving of operators that don't take the time to fully understand all of the different modes and controls and limitations of operations. For instance, the Typhoon actual flight time is more like about 14 - 17 minutes or so depending on conditions and this is no where to be found in the manual or on any Yuneec literature but it is in this forum. Also; admittedly, DJI's upcoming Phantom can fly across the continent or 2,504 nautical miles or some such thing - the H can only fly a tiny fraction of that but still; it will be well beyond VLOS so, if you need or want to fly illegally - DJI wins hands down in that category
So I would say - great value, good camera platform, dedicated controller and screen, solid performer and; an awesome forum to boot. Go for it.
