Only getting about 150 foot video range
ofg
Next issue with h plus. Im only getting about 150 foot video range before it starts pixelating, going cloudy, fading in and out. Control range seems fine. Video has been short range from new. Seems like even stock antenna should give probaly 10 times that range. Mine came with 2 different antenae. One is round, other is square. What the difference?
Use the square antenna on the center port and make sure it's pointed at the aircraft. The mushroom antenna is omnidirectional. If you use it point it straight up. The stick antennas should be pointed straight up but at an angle left and right to form a V.
Will do. I may eventually get a high dollar antenae outfit, but would like to get the most from the stock equipment for sure. I should be able to test journey and square antennae on monday or tuesday.
aatechnology
