Hi,
Safety parachute can use manually and automatically deploy, on the same time.
In France, when you fly on urban areas, as professional drone operator only, with a drone more than 2 kg, the French regulation imposes you to fly with a safety parachute approved with separate system from the drone radiocommand to trigger. You could use automatic both, if you like. Each safety parachute system need a test in real conditions, to be approved by the french transport authorities.
For automatic, you could use mayday card for example:
Mayday Boards – UAV Flight Safety
Features:
– Standalone System with No Pilot Interaction Required
– Fully Programmable
– Ultra Bright LED System for Daylight Use
– Light Weight, Compact and Ready for Flight
– Ready to Pair with Any MARS Parachute Recovery System
– Auto Deployment Functionality
– No Flight Controller Connections Required
– Inexpensive Safety that Cannot be Ignored
– Expands Your Altitude Margins
– Increases the Envelope of Capability for Any UAV
For manual trigger, you could use FTS system, made by EvoSystems (Italy):
The system is composed of the Master module (remote control for the pilot) and the Slave module (installed on the UAV). The radio communication between the units takes place on the 869 MHz at 500 mW. A license-free band, in compliance with the European regulations CEPT 70-03.
The radio communication is also secured by 128-bit encryption that prevent any rogue use of the system by third parties.
An important feature of the system is the Keep-Alive, which allows the Master module to poll every second to check the link between the Master and Slave. The keep-alive signal is displayed by the white LED.
When the Master doesn't receive a signal from the Slave, it emits an audible alarm and flashes a white LED. As soon as the link is restored, the alarm goes off and the connection is resumed.
For manual trigger, you could use Opale Parachutes (France) system too:
Remote for parachute system - 868MHz - 2.5km (1.55mi) range
Opale Parachutes - Remote for parachute system - 868MHz - 2.5km range
Features:
- Designed to cut the UAV power and trigger a parachute
- 868 MHz, 500 mW
- 5km tested range
- Keep-alive, alarm on link loss
- Low battery alarm
- Receiver can be powered by its own battery
- Aircraft like safety switch with cover
- European radio regulations compliant (CEPT 70-03)
- Good build quality
