possible to recover on-board video contents from a damaged Breeze?
Just experienced a really bad crash and Breeze actually fell into water. I can still hear a beep after connecting it with a PC via USB, but the PC says the USB device is not recognizable. Anyone had similar experiences and was able to recover the video contents in on-board memory? Would I be able to boot the single main PCB with all connections to others disconnected?
I cannot see wifi connection from Breeze....
It sounds as if the A9 board that contains the internal SD card, USB interface, and WiFi is damaged.
You can try doing the reset procedure to recover functionality, but the odds are not in your favor. You can find the reset procedure here How To: Troubleshoot the Breeze and Request Help in the Forum.
thanks for reply. If the video cannot be recovered, I probably will give up Breeze and move on to something else. This breeze has been problematic since day one....., sadly...
Alvaro
