Problems CGO3+
More problems with my Typhoon H.
Problems related to :
- taking pictures
- taking videos.
I can, sometimes take a photo, never more, and no videos (by choosing of course the mode or camera or photo)
And this without SD card inserted in the camera.
State of play, perhaps an expert will understand my difficulties:
- in the menu "System Setting "s the selected camera is CG03P_820C70
- on the camera I read CG0+
- In the "About Controller" menu
- the paragraph ST 16 is filled in (system Version, transmitter Version, Radio version)
- but the paragraph Typhoon H, displays:
- Gimbal N/A
- Autopilot version: N/A
- Camera : version N/A
- RealSense tm: N/A version
Is the SD card necessary in the camera?
What is the purpose of the micro USB plug located near the SD card slot?
Sometimes at 50 m height, the video return stops, I have to lose altitude to find it.
How to measure the range?
Note: the "screen shot" always works and all the time.
How should the two antennas be arranged? And the mushroom antenna, should it be directed towards the drone, and how?
How come this drone, which has so many qualities, causes so many problems to one or the other, and how come the documentation, except here of course, is so poor?
Thank you all for your answers.
Translated with www.DeepL.com/Translator (free version)
Yes, if you want to take photos or record videos. SD card has to be fast enough for 4K videos, Ultra HC Class 10, U3 (a small 3 in the 'U').
CG03P_820C70 is the SSID of your CGO3+ camera. It will connect via WiFi.
If no FW versions will be displayed, the drone is probably not bound. Check correct binding in Bind menu. See bind procedure in docu.
At the camera? It has no function and is not connected to anything.
At the ST16 it is to connect the ST16 with PC.
The musroom antenna (=5GHz WiFi for video downlink) and also the rod antenna (2.4GHz ZigBee for RC) should never directed to the drone. Maximum radiation is around the antenna.
I don't know what docu you have but it is not so bad. You must read it and follow the recommendations.
Salut Dominique, tu n'as pas de manuel d'utilisateur ?
Sans carte Micro SD dans la caméra, rien ne fonctionnera, pas de prises de photos/vidéos, donc OBLIGATOIRE !!
Carte Micro SD de classe U3 ou V30 de 32 GO ou 64 GO, c'est ce qu'il y a de mieux pour l'image et de la vidéo 4K avec un bon débit.
Pour les antennes, les deux antennes bâtons doivent toujours être légèrement inclinées et repliées de 45° pour couvrir le plus de surface possible, l'antenne GPS au centre dois pointer ver l'appareil pour avoir une transmission supérieure.
Je te conseille de télécharger un manuel en Français (facile a trouver sur internet) et de le lire, ça t'évitera d'écrire ce genre de commentaires.:)
Translation:
Hi Dominique, don't you have a user manual?
Without Micro SD card in the camera, nothing will work, no photos / videos taken, so COMPULSORY !!
32 GB or 64 GB class U3 or V30 Micro SD card, this is the best for 4K image and video with good bitrate.
For the antennas, the two stick antennas must always be slightly inclined and folded back 45 ° to cover as much surface as possible, the GPS antenna in the center must point towards the device to have a superior transmission.
I advise you to download a manual in French (easy to find on the internet) and read it, it will save you from writing this kind of comments. :)
Comment se fait-il que ce drone, qui a tant de qualités, pose tant de problèmes à l'un ou l'autre, et comment se fait-il que la documentation, sauf ici bien sûr, soit si pauvre ?
This is not true. I think he has a ST16 with only two external antennas. One rod antenna 2,4GHz, one musroom antenna for 5GHz WiFi. The GPS antenna is always inside and hidden.
If you have two external 2.4GHz rod antennas (the 3-antenna-ST16) then those two should have an angle of 90° to each other. The angle to the cover plays no role. The mushroom antenna should NOT pointed to the drone!
When holding the ST16 to control the aircraft the mushroom antenna should be positioned so it looks like it is growing out of the ground.
Ce n'est pas vrai. Je pense qu'il a un ST16 avec seulement deux antennes externes. Une antenne tige 2,4 GHz, une antenne champignon pour le WiFi 5 GHz. L'antenne GPS est toujours à l'intérieur et cachée.
Si vous avez deux antennes tiges externes de 2,4 GHz (la 3-antenne-ST16), ces deux-là doivent avoir un angle de 90° l'une par rapport à l'autre. L'angle avec le couvercle ne joue aucun rôle. L'antenne champignon ne doit PAS pointer vers le drone !
In French il parle bien des deux antennes bâtons et de l'antenne champignon, pour la position des antennes et leurs orientations, les antennes bâtons sont directionnelles, si elles sont dans l'alignement de la ST16 la réception sera moins bonne que si elles ont un angle de 45°, comme l'antenne champignon.
un petit mémo sur les antennes => Conseil orientation antennes sur drone
In French he speaks well of the two stick antennas and the mushroom antenna, for the position of the antennas and their orientations, the stick antennas are directional, if they are in the alignment of the ST16 the reception will be less good than if they have an angle of 45 °, like the mushroom antenna.
a little memo on the antennas => Conseil orientation antennes sur drone
Lorsque vous tenez le ST16 pour contrôler l'avion, l'antenne champignon doit être positionnée de manière à donner l'impression qu'elle pousse hors du sol.
exact!
If you have the two external antenna ST16 position the antennas as shown here.
If you have the three external antenna ST16 position the antennas like this.
Many thanks to h-elsner for his patience and his answers.
I do not believe that the documentation we have in France is sufficient to solve the numerous difficulties of the Typhoon H which suffers, it must be admitted, very often from small incidents (more than its competitors of the same category). The messages from the pilots here testify to this.
But I asked yesterday, how to measure the range? like in aeromodelling? you establish the connection, and you move away with the ST16 until you lose the effect of the signals? The wi fi connections seem very loose, and below what the literature says. Is there a way to increase the transmitting and receiving power?
Un grand merci à h-elsner pour sa patience et ses réponses.
Je ne crois pas que la documentation dont nous disposons en France soit suffisante pour résoudre les nombreuses difficultés du Typhoon H qui souffre, il faut bien l'avouer, très souvent de petits incidents (plus que ses concurrents de même catégorie). Les messages des pilotes ici en témoignent.
Mais j'ai demandé hier, comment mesurer la portée? comme en aéromodélisme ? vous établissez la connexion, et vous vous éloignez avec le ST16 jusqu'à ce que vous perdiez l'effet des signaux ? Les connexions wi-fi semblent très lâches, et en dessous de ce que dit la littérature. Existe-t-il un moyen d'augmenter la puissance d'émission et de réception ?
Traduit avec www.DeepL.com/Translator (version gratuite)
La portée WiFi 5.8 ghz pour les Typhoon H version EU (Europe) est d'environs 1600 / 2000 mètres, c'est a cette distance que tu va perdre le retours vidéo sur
l'écran de la ST16, bien sur ça dépend des obstacles, interférences, perso j'ai poussé mon 1er H480 a 1600 mètres de distance avec retour image en montagne.
La portée de l'appareil en lui même, et la on passe sur du 2.4 ghz bien plus fiable passe a 4500 mètres en horizontal et 2200 mètres en vertical, bien sur
a ces distances tu a plusieurs paramètres a prendre en compte :
1- L'autonomie de la batterie, tu n'a pas assez de jus pour rentrer.
2- La vue, tu ne verra plus ton appareil et c'est interdit en France.
3- essaye déjà de voler a 4/500 mètres de distances pour te rendre compte que le Typhoon est un petit point dans le ciel.
Pour augmenter l'émission/réception sans trop trafiquer la machine est d'abord d'acheter de bonnes antennes pour la ST16, tu peut ensuite faire débrider ton système en passant en mode US, en France tu a First-Drone qui est spécialisé YUNEEC qui fait ça.
A tu ce manuel d'utilisateur ?
  • notice_yuneec_typhoon_h.pdf
Reactions: h-elsner
BengalFlight
