Problems getting my chroma blade to start.
Milton Keynes uk
Hi, I'm new to this group.
I haven't used my chroma blade for a while, and during this lockdown, I thought I'd get it flying again.
So... I've paired it, the camera connects, it says welcome pilot. But I have 4 solid white lights and the drone is making 4 beeps like... beep beep, dud dud.
Where can I find a fault finding page or can someone point me in the right direction of what's occuring?
Thanks in advance
Reactions: Blaydestone
Was a battery left in the drone?
Not a good sign when a LiPo battery leaks like that. If you still have it, soak it in a bucket of salt water for 48 hours then recycle it or place in the trash.
I don't think there is anything wrong with the battery. No signs of leakage
Do u know if the is a troubleshooting guide for the beeps that the chroma blade makes?
That's signaling "Emergency Mode", which normally comes from a motor failure or a prop hitting something. Yours is probably coming from the board damage, or course.
I don't have a list of beep codes. Here is the "Cheat Sheet" for the Chroma.
  • Chroma_LED_Codes.pdf
The only solid white light code on the cheat sheet is when the GPS is turned off.
I turned my Chroma on with the transmitter off and the LEDs slow flashed white to indicate no transmitter.
I unplugged a motor and after initialization and starting the motors the Chroma went into Emergency Mode and the LEDs quick flashed white and beeped.
Have you tried the Chroma GUI app to check if you have any sensor issues?
RG
sakshijah
