Q 500 typhoon
Turn off the gps. It goes plenty fast that way.....and tends to nose dive dramatically so low passes at high speed are not recommended.
I've never tried it, but I have seen a video showing a way to go to a "secret menu" on the controller and getting more speed. If I can find it I'll post the link
Reactions: Doug coppins
If the sticks go to 100% in Rabbit mode (with GPS on), you cannot gain more speed by any adjustments. The max speed is determined, at least in part, by the maximum angle the aircraft can tilt as determined by the Flight Controller. Increasing the tilt angle steeper than the max results in loss of altitude. Turning off the GPS and running at max speed also results in loss of altitude.
ankit09sharma20
