Q500+ Battery Door Replacement Procedure?
I have to replace the broken battery door on my Q500+. Is this a difficult Job?
Where can I find instructions on how to replace the door?
Thanks in advance for any help.
Is the door broken or just the latch?
If you have to replace the door it will take some time. You have to open the airframe which is about 63 screws. You need long shaft hex drivers: 1.5 mm, 2.0 mm and 2.5 mm. Here are parts for the door depending on what you need: Search Beta
This is a video on how to replace the door. The video quality sucks, but it's the only one I could find.
How can you fix the little click in to close the door ? I’m pointing it with my finger. Thank you. Is not strong enough to hold it closed.
What type of screw is in the replacement female section on the bottom of the craft.
My wife doesn't see and me either where the inside part of the screw seems to have no kind of Philip's or flat screw. Almost impossible to see. They are not like the replacement ones which look the way I understand. Can't get the old ones out. This is another easy one and sorry for having to ask.
dharminder
