Q500 Minor Crash - CGO3 Problem (PLEASE HELP!)
I had a minor crash yesterday. Nothing broke except a prop. The gimble wires also became detached. I didn't think anything of it and merely plugged in the cord from the bird to the gimble that came with it when purchased. Everything fired up fine. The CGO3 calibrated perfectly. I took it back up, flew around for a bit then tried to pan down. NOTHING HAPPENED.
So everything works except the pan up/down function. Interestingly, the gimble is perfectly stabilized - including up/down, just won't respond to the command to pan up down. I expected that it wouldn't be stablized up/down if the command isnt working but it is.
Where do I start with this?
Thank you so much for any suggestions!
ploomy
