Question for FPV
Y
Yuneec Pilot
Guest
Hi i am currently picking my own fpv set and I thought:
If I use a Cloverleaf antenna in air, do I need a cloverleaf on the ground too? Because most monitors only have the normal pole antennas attached.
Hello
It is recomanded to use the same type of antenna.
If you have Cloverleaf on you Drone, you must have same on your FPV googles.
Generally, 3 leaf on the drone and 4 leaf on the FPV googles.
Your welcome.
TroyBoy
