Question on breeze leds...
Ok I cleaned off whatappeared to be extra solder on that mosfetwith damage tothe insulator , now the boards passed all the checks and I can connect to it an it reads ok minus the missing boards.
I also used a volt meter and took reading on that MOSFET pin to pinand got same readings as one two up from it does that mean it may fly ok when I resemble this breeze?
Would the breeze pass all the check list test with a bad mosfet or esc?!
BengalFlight
