Reflash my drone just had the white connector hanging loose under the cap.Here’s 3 combination ideas in solving this.
1) Install a main Tri-color LED.
(unflashed and flashed to register the build parameters)
2) Re-flash H Plus, without the RS.
(register the build parameters)
3) Do both 1 and 2
You can change the size in the app under settings.Hello thanks for the feedback on build 822. Q. Can you change the still photo options on this build?
I have 822 and you can change the still photo options but I always get the the photos in 1280X720.
Am I doing something wrong or is it the build? Thanks!
1280x720 sounds like the preview file on the remote Are you taking them from the SD card in camera?
@RPR: One question: What program did you use to capture the FPV display on the ST16s?
I've tried some screen recording programs from Google Play store but none of them worked as they required the machine to be rooted (rooting the Android system, voids the controller warranty).
Actually had a thought about the RS.
Since the plugin connecter just hangs in there wouldn't it be possible to mount a micro switch on the outside on the drone to turn it on and off when needed?
Good point [emoji108]I would not add an inline kill switch if you are not able to assign its use in PX4, because you will create a “bias unknown” that can trigger a domino effect of problems. Or you have to reflash all the time, when you switch the trigger On and Off to be able to accept the new parameters in the build.
I just shielded mine as well, unbelievable how much interference the RS module emits.
Thanks for the tip.
Thanks for the tip.
I didn't have any cobber tape lying around. So just used some chocolate wrap [emoji23] it was available and you get a little joy out of it.
Other than that same installation as RPR.
Did a phone test just before assembly and it completely blocked the signal so should be good enough for this. View attachment 16074
