This proposal establishes design and production requirements for two categories of remote identification: standard remote identification UAS and limited remote identification UAS. Standard remote identification UAS would be required to broadcast identification and location information directly from the unmanned aircraft and simultaneously transmit that same information to a Remote ID USS through an internet connection. Limited remote identification UAS would be required to transmit information through the internet only, with no broadcast requirements; however, the unmanned aircraft would be designed to operate no more than 400 feet from the control station. Under this proposal, the vast majority of UAS would be required to comply with one of these two categories of remote identification. For those limited exceptions, which include certain amateur-built UAS and UAS manufactured prior to the compliance date, operators flying UAS without remote identification capabilities would be permitted to fly only at certain specific geographic areas established under this rule specifically to accommodate them.
This proposal envisions that within three years of the effective date of this rule, all UAS operating in the airspace of the United States will be compliant with the remote identification requirements. No UAS could be produced for operation in the United States after two years and no UAS could be operated after three years except in accordance with the requirements of this proposal
1. UAS Owners The FAA proposes to revise the registration requirements to require all owners of unmanned aircraft to register each unmanned aircraft individually when registering under part 48. Furthermore, the owners of standard or limited remote identification unmanned aircraft would have to provide the serial number of all unmanned aircraft registered under part 47 or part 48, on or before the 36th month after the effective date of the final rule. The serial number would establish the unique identity of the unmanned aircraft. The serial number provided during registration or re-registration would have to be issued by the producer of the unmanned aircraft and comply with the ANSI/CTA-2063-A serial number standard. Owners of unmanned aircraft used exclusively for limited recreational operations5 who currently register multiple aircraft under a single registration number would be required to register each aircraft, individually by manufacturer, model, and, if the unmanned aircraft is a standard or limited remote identification unmanned aircraft, the aircraft’s serial number, on or before the 36th month after the effective date of the final rule. The owners of small unmanned aircraft registered after the effective date of the final rule would have to comply with the new registration requirements prior to the operation of the unmanned aircraft.
