How does one remove this as I have th screw out, but it doesn seem to release, so I'm missing something ?
The xacto/ hobby knife's the trick thanx againYup. I just removed one using a kitchen knife. A little thicker, and had to look more closely to get it under the spring, but it worked fine.
I've actually seen that many times. The spring latch can break completely and fly out during a crash but the screw is still in place.I notice the video started with the latch already removed. For some reason, the screw was still in.
Lift the motor arm before pressing the release. If there is tension on the spring it will not release until you lift the arm.so I gave more pressure and it broke the spring clip
