Is there a trick on unpluging the wire connector plugs, I gave it a go but dont want to apply to much pressure until I know if thats whats needed one side wiggles a bit ? This is my first attempt at a repair why I'm cautious
Are these the plugs you refer too?Is there a trick on unpluging the wire connector plugs, I gave it a go but dont want to apply to much pressure until I know if thats whats needed one side wiggles a bit ? This is my first attempt at a repair why I'm cautious
Sucess I watched that video althou it was in sweedish I got the drift, I replased the whole switch panel ? I just get anal when I'm unsure I gave up years ago when just diving in, and breaking more things then had to be fixed.Are these the plugs you refer too?
What happens when you dis-connect the battery from the controller, tryin to charge the battery but its a red instead of white battery screen with a yellow exclamation mark ? should I disconnect it, or let it go its been this way for less than 2 mins ?Sucess I watched that video althou it was in sweedish I got the drift, I replased the whole switch panel ? I just get anal when I'm unsure I gave up years ago when just diving in, and breaking more things then had to be fixed.
You can keep it fully charged it's a Lithium ion battery, you'll have to keep an eye on it to make sure it's not discharging dramatically, it maybe because something happened when you reassembled the controller?What I cant figure out is how the st16 battery went from a full charge before disconnect to 8% (hence the red battery display on the screen in charging mode), it just doesnt make any sence ? Heres what I got the battery display in chargeing went from red (with the yellow exclamation mark) to orange, or yellow, then the normal white ?
Thanx, I thought that was really odd, Does the 16, and 16s use the same battery as I will buy each a spare ?You can keep it fully charged it's a Lithium ion battery, you'll have to keep an eye on it to make sure it's not discharging dramatically, it maybe because something happened when you reassembled the controller?
No different ones, the ST 16s is more expensive and slots in, not plug inThanx, I thought that was really odd, Does the 16, and 16s use the same battery as I will buy each a spare ?
