[Rupprecht Law]-FAA clarified which Class E airspace requires a COA.
Section 107.41 says, "No person may operate a small unmanned aircraft in Class B, Class C, or Class D airspace or within the lateral boundaries of the surface area of Class E airspace designated for an airport unless that person has prior authorization from Air Traffic Control (ATC)."
There was some confusion as to which Class E airspace the FAA was talking about. It's important to know which Class E at the surface airspace applies because NOT all Class E airspace requires a COA. The FAA clarified this in an internal memo.
https://jrupprechtlaw.com/section-107-41-operation-in-certain-airspace
Reactions: PatR
Yep. Just the E2 within the closed area around an airport. But interestingly enough around some E airports the LAANC system will indicate authorization needed, but show a 400-foot cap, outside the actual E2 airspace. Kind of weird. Artifact of the way the LAANC boxes are drawn I think.
This is a nice E airspace article:
BTW - for those that don't follow Jonathon Rupprecht his blog is great stuff for the legal side of the industry.
That outside 400’ cap makes sense as LAANC as currently used is designed around commercial sUAS operations. Since commercial operators have a 400’ cap, unless a structural inspection gives cause for modification, that “outside” cap is just repeating what a commercial operator should already know.
I was talking about in other than E2 airspace, LAANC will sometimes show authorization needed. The 400-foot cap was sort saying it was redundant because once outside the surface area of E airspace airports the altitude cap is 400 feet anyhow.
daps20
