SD Card GIG Size.
Hull
Hi all,
I'm looking for two answers if possible please,
1 - what is the largest GIG SD card I can use as the 16 isn't big enough?
2 - what is the best type of card to maximise the 4k photo/video quality?
Thanks in advance guys & girls
1 - I think most people stick to around 32-64gb although you can probably go to 128gb. The camera will read FAT32, and ExFat, but not NTFS, remember that when formatting the card. At least I noticed I can read ExFAT with the latest firmware.
FAT32 will only read up to 32gb so if you go above that you need ExFAT. The easiest thing to do is to just download and use the SD Card Formatter from here https://www.sdcard.org/downloads/formatter_4/index.htm
A lot of good info here - Chart of CGO3+ Files Sizes
2 - A good U3 SD Card should be fast enough.
Reactions: Cort01
Axel66
