Sensors Not found after repairs.
Hi
Been off for a while, medical stuff plus my Drone was in for repairs after it fell out of the sky and crashed.
Covered under warranty due to battery door failure, causing loss of power.
Anyway got it back today after being repaired.
Charged batteries etc, then went to calibrate etc.
On turning on Drone and RC I noticed error message on RC
Mode : Pre Fail
GPS: disabled
All worked fine prior to repairs???
Went into settings and turned GPS on, but it won't stay on, on entering setting I see its OFF.
So I connected drone to PC via Yuneec software and noticed 2 errors
Pressure Sensor X Sensor Not Found
GPS
X Sensor not Found
Any guidance appreciated.
I would guess that they did not connect the the GPS antenna and the pressure sensor back in before closing up the bird.
They had allegedly test flown the bird.
Will have to make contact with them, they had the ting for over 2 months.
Hi
Made contact with repairer and seems loose connection belongs to GPS.
So removed body and reconnected and all good again.
Time for a test flight and what do you know must be a bit rusty and crashed.
2 broken props and the camera mount came adrift,
Now I have 3 wires I can't account for can anyone assist with I can rectify.
Uh oh , that stinks. Hopefully you can just use the jumper cable and be fine unless there is more damage then those 3 wires.
cegimo2215
