set waypoints without using CCC
how to set waypoints on the H Plus without using CCC . I wanted to preset a flightpath on my laptop and use it on the typhoon H plus,,, how can i do this
If I used QGround control, and save as *.plan, is that same format as DataPilot *.plan file?
AND THANK YOU TUNA!!! Can't wait to try this out.
Yes, DataPilot and QGroundControl are essentially the same software for mission planning. However, you will need to set up an appropriate camera profile in QGroundControl. DataPilot already comes with a profile for the E90 which is to all intents and purposes the same as a C23 (HPlus) camera.
Reactions: Trav H
corteizshop
