Some SD cards not working cg04
hello how to update the cg04 camera some sd card does not work thank you
If your camera is working it might be best not to try updating it. It is very likely it is already fully updated as the latest firmware was released in 2016 or 2017. With the aircraft and camera on and bound to the ST16 from the main screen go into System Settings, About controller, and post a screenshot that shows the firmware versions.
Bonjour voici une photo merci
Bonjour voici la photo de m st16
You have the latest firmware on the ST16, but the camera is not bound to the ST16 (no WiFi link). In the other thread you stated the camera and aircraft were working so you need to have them powered on and binded to display the firmware versions for autopilot (aircraft), camera, and gimbal. There is no RealSense for the H920+.
I know 16GB and 32GB SD cards formatted as FAT32 will work in the CGO4 and need the U3 rating to be able to record in 4K. I think it will also work with 64GB and 128GB SD cards formatted as exFAT (formatting them as FAT32 reduces their usable capacity to 32GB).
Bonjour
Je pense q’il sont bien reliés vue que j’arrive a prendre des photos et des vidéos
Donc je ne comprends pas tout la
Merci
Hello
I think they are well connected since I can take photos and videos
So I don't understand all the
Thanks
Did you have the aircraft and camera on when you went to the About Controller screen in the System Settings?
On the H920+ with the CGO4 camera mounted even though the camera is bound and working, the "About" screen only shows data for the ST16 for unknown reasons. This has always been the case on mine.
However, when mounting a CGO3pro camera, both the ST16 and CGO3pro firmware data is shown as seen in these screen shots.
Thank you ever so much for that tidbit @SkyVidTek !!! I’ll file that in the memory banks and hope senility allows recall the next time it is needed.
@Mb69 do you have a CGO3+ that can be attached to see what version your AutoPilot is on?
That confirms it will accept up to a 128GB card. 👍
amazon global selling
