SR 24 / SPARE YUNTYH135SVC
I need to connect the sr24 transmitter to a cc3d or pixhawke flight controller via the dsm port.
On Yuneec ST24 receiver and Pixhawk autopilot announce
there is an indication, but the cables coming out of the transmitter have a different color and next to it is a 4-pin plug is present.
does anyone have the pinouts of all the transmitter cables?
Hello,
have you connect successfull st24rx on pixhawk spektrum/dsm connector, ??
best regards
Pat4si
Yes, the st16/24 is fully connect with the pixhawk. The sr24 is also fully compatibile with the gb203 (there are a Hide port in the front of the gimbal control board. Befor give Power YouTube need push the button in sr24 and pair It with st24 or st10 (this station is compatible with gb58 GoPro control)
thank you for reply,
j have yuneec ST 24 with sr24 rx and connect sr24 rx to pixhawk :
at spkt/dsm 3 pins connector .
black wire sr24 rx to PIN2 ( gnd )
white to PIN1 ( + vcc ) 3.3v or 5v ??
grey ( not connected ) data IN
yellow PIN3 data out
but nothing !
Have I forgotten something?
best regards
Pat4si
j do not thing so, because j dont know how ?? j do push and main the small button and power on?
but j do not snow if spectrum/dsm connector as 5v, j have tested PIN1 and nothing !
ok, j push button sr24 rx when power on and small led flash, but none st24 or st16 bind, none see sr24 rx when push button scan !!
Pat4si
The st24 is 3.3v in according with the dsm pixhawk port.
In the instruction offline sr24 i find this: push the button and then Power up the board.
Ok, on my clone the sptk/dsm pins connector were poorly welded and now J have 3.3v on pin, but J do not bind with ST24 my SR24 rx.
the led is flashing when push button on power on, but DR24 is not recognized on ST24 tx ! what profil use ? RC or FPV ?
best regards
Pat4si
both RC or FPV not detect my ST24 rx !! its stay flashing !
best regards
Pat4si
Hello,
can you say what is the right whith yello, grey, black,white lead and left connector on pcb, ?
best regards
Pat4si
airconditionerservice
