ST10 Joystick Movement
Hi, I can't figure out the joystick movement on the ST10 and don't want to trial and error it out in case it crashed. Here's a photo of the selection; I don't know what RUD, THR, ALI, or ELE (but I'm assuming it's elevation). The photo is below. All help will be appreciated!
Reactions: Bean
Mode 2 is the standard mode, and is already selected in your photograph. Almost no one uses the other modes. It makes it very difficult to discuss stick movements if someone is using anything other than Mode 2.
Reactions: Bean
I usually have my right joystick control rotation and elevation and the left joystick is front/back/left/right. Is that mode two?
Reactions: Bean
No. That would be Mode 3, if I understand what you want.
In Mode 3:
Right Stick:
Vertical controls throttle (Drone moves up/down)
Horizontal controls Yaw (Drone rotates left/right)
Left Stick:
Vertical controls Pitch (Drone forward/backward)
Horizontal controls Aileron (Drone moves sideways left/right).
Reactions: Bean
In Mode 3:
Right Stick:
Left Stick:
Yes, that's what I mean. Thanks
Reactions: Bean
pawansingh979937
