ST10+ update ???
Southern Cali
I'm trying to update mine as well. Only got the TX file in the download. Downloaded the Bin file from Yuneec website but every time I try to install it on the controller it gives me a failure error stating “Reason:Timeout” I've tried several different micro SD cards from 1GB to 16GB. Same result every time. Any suggestions, thoughts or ideas are appreciated.
Hi GeorgeR. I had the same problem here. After a few attempts I found that opening up the TX folder to expose the sub folder before placing the card it in the ST10+ did the trick. I don't know if this was just luck or whether it is a requirement. Hope it works for you too.
regards,
Geoffrey Lear.
jonnyelectric
