St16 update.
Does anyone here know what the current firmware is? I haven't used mine in a while and want to make sure it is updated. ive tried doing the wireless update but keeps telling me network failed. currently the firmware on my controller is System: st16_system_V3.01.01.b30
APk: st16_app_v01.00.45
Welcome to the Forum.
Your controller firmware is current.
It is generally not a good idea to update firmware unless there is a real need. There are a lot of "failed update" stories here on the Forum that describe the miseries encountered when folks did updates "just because".
SD card updates can be used if needed, but there are no further Typhoon H updates expected.
One reason might be camera selection. What you see on screen is affected by which camera. Also by stuff like which flight modes you might have selected.
But if you are concerned about what you see, you can upload a screenshot and tell us what is different.
Reactions: DoomMeister
Mine is the one with the mountains while the drone is off
The mountains are normal for a Typhoon H with an ST16 controller. The other image is from a Typhoon H520 and is on an ST16S controller. Yuneec did not update the "ST16" label when they issued the ST16S series. This is not the first time that bit of laziness has caused confusion.
Hodgepodge
