- Joined
- Jan 4, 2019
- Messages
- 483
- Reaction score
- 677
- Location
- Citrus Heights, CA
- Website
- yuneecskins.com
How To Tip - If your getting a weak Video Feed from your Camera to your Controller, this How To Tip may Solve this issue... I've been seeing this problem more often.
Cause: Yuneec moved the 5.8gHz Video Antenna to the Center of the Controller between the 2-2.4gHz Whip Antennas on all 3-Antenna ST16 Controllers (All ST16 Controllers) the only drawback to this is; there is No Stops cast into the Plastic ST16 Housing to Keep the Brass Jack Plug from Spinning Freely when Attaching the Patch, Mushroom Video Antennas, or Adding a Range Extender to the Controller, if the Jack Nut Spins it will Twist & Break the Coax Cable, or Frey & Short it out, causing weak reception, and Signal Loss at Short Range from the Camera... If you find this Fix Solves this issue, please let us know...
