ST16E Firmware File needed
Hello.
For some unknown reason i thought that the H520E Copter is using the ST16S Remote Control, wrong, it´s the ST16E!
So i thought "Hey let´s update the Remote Control Firmware Stuff". I downloaded the update.zip for the ST16S and installed it via the SD-Card on the ST16E,
now i can´t connect the Copter to the ST16E anymore, because of the wrong update.zip (i think that must be the issue).
It would be very nice if someone can help me out with sending me the correct update.zip file for the ST16E Remote Control, or maybe can tell me how to fix it in another way.
Maybe someone from the Yuneec Staff or so.
Support is very very much appreciated! I can´t connect the H520E (CGOETx) anymore to the ST16E because of the wrong Firmware on the ST16E.
Some additional informations:
Build-Number on the ST16E before the update:
"ST16S_CONTROLLER_1.0.16_BUILD68_20201023"
Build-Number on the ST16E after the update:
"ST16S_CONTROLLER_1.0.11_BUILD532_20200103"
Kind regards
Sven
The build number you currently have (the one you updated in error) is the same build number of the "update.zip" that is in the DropBox Archive provided by @Yuneec Skins
I would contact him... (he will probably see this post and respond). Ask if he has a copy of the previous update that he can send you.
OneIndiaPestControl
