ST16E No Display
Austin, Texas
Good morning and happy Friday from Texas All! This is the second time I am noticing an issue where after powering the RC that neither the LED next to the switch or the screen power up. I can hear the fans and tried several batteries but no display. I even tried to plug it in to see if I could get the battery charge indicator which worked the last time this happened but nothing this morning. I swear last time it happened I gave it a little tap and it started working but that could have just been by coincidence.
I know you are more familiar with Yuneec (or any other company) than most, so I will mention "If it's under warranty, send it back" for the sake of others.
The fact it may have responded to "percussive maintenance" ("gave it a little tap", "whacked it with a hammer", etc.) brings into possibility a bad connection somewhere.
Possibly corrosion on a ribbon or cable connector. Those can be checked and cleaned.
Unfortunately, also possibly a cold solder joint, cracked solder, or a failed component. Those can be narrowed down a bit if you have another controller you can use to swap parts around and find find the board with the issue. Otherwise, it becomes a time consuming and likely unproductive exercise in playing hide and seek. Since the blue light is acting strangely, I would start with the switch itself.
If the problem can't be found by cleaning the connectors, it will probably be best to send it for repair.
Reactions: DoomMeister
Thanks for this. I have already contacted support and am waiting to hear back but I too am afraid it is a connection issue. I have now powered it off and on several times successfully so hopefully I can get through today. Sketchy, but even with the screen off the switches sill worked. There's something to be said for mechanical switches... I'm talking to you Tesla!
  • Haha
Can you measure the voltage of the battery? This sounds like some charging circuit issues that cropped up in other versions of the ST16.
I just saw @WTFDproject post and agree with his assessment. The switch is a good place to start, but the issue of no screen with the switches functioning sounds like it could also be a backlight issue also.
With this being under warranty they should send you a replacement and return shipper for this malfunctioning one. QC needs an update to their practices.
I tried 4 different fully charged batteries. I'm sure we'll be getting a replacement. Looking forward to all the updates and reconfiguration!
daps20
