Strange beeps from TH? Or normal?
Northern Italy, near Verona
Today waiting gps acquiring I touch with the finger the right stick, and heard a fast beeping when I move the stick into the four directions (see video)
Is it a normal behavior? I don't remember having heard these sounds before.
Video
Video
It is completely normal. The beeping is intended as a warning when the signal from the right stick is not centered. It keeps you from taking off and having a sudden movement of the drone across the ground or tipping over. You will also hear the beeping if the sticks are off center due to a problem with the stick pots, such as corrosion.
Ludwig
