Strange situation with Breeze 4K
Hello!
Didn't fly my drone for a while and now something strange is going on.
1) I turn on my drone (Breeze 4k) and it goes to blinking blue ("bind" mode).
2) iPhone "sees" WiFi and app tells me that drone has been connected
3) but there is no connection really: grey icons for connectivity, OFM, IRS, GPS... Basically, no connection at all.
Could it be because I overcharged battery? Which I did btw...
Will appreciate any recommendations!
Regards,
Vlad
Not sure which iPhone and version of iOS you are running, but the newer versions of iOS are causing problems with connectivity when cellular is active.
Try placing in Airplane Mode, then enabling WiFi (and Bluetooth if you use the Breeze Controller) before trying to connect.
Please report results and which iPhone and version of iOS.
Thank you!
I will try later today and report results.
Meanwhile: iPhone 6s, iOS 12.3.1
The 6S is fine, but 12.3.1 is causing the troubles.
It worked after i switched to Airplane mode.
Thank you!
Telefoni
