Trouble connection to camera
Hi all,just looking for some help here. Every time I start up my drone I have to manually go in and connect to the camera. This only started lately,is there some way I can prevent this as it’s a bit of a pain
Have you used the search tool yet to see if there is a solution? In the upper right corner there is a magnifier that you click to search with. You can also go to the relevant section for your craft and look in there.
My suspection is the WiFi connects to another hospot first.
Go to pad mode > settings > WiFi > Check if another network is connected when the CGO3+ is not. Select this network and set it to 'forget network'.
Another try would be to create a new model from scratch and connect cam and drone to that.
fabricolaundry
