Typhoon 4K of some afternoon snapshots
Did some video testing from the video that captain drone did with all his settings. Yes some of it works but you really need to watch the lighting even when it locked. I found if the lighting changed even a little bit you can end up with a over exposed video.The white balance was set to the water in this video. It does work but you need to pay attention. If your not into that then just use auto video settings and away you go :)
Just my opinion but it looked like you had it set too bright from the beginning. I believe the whole video would have been better if it were a bit darker.
NetsolWater
