Typhoon h as an antenna
Carharrack, Cornwall UK
Can anyone tell me what each connection does where the camera attaches? I'm trying to make a video relay with a video receiver linked to a small transmitter which will relay the video from the ground. I'm not planning to use the camera on the typhoon h, I only want it to follow the wizard and relay the video feed.
Not sure what you are asking.
If you are talking about the "hot shoe" type connector between the camera/gimbal and the drone body, none of that has anything to do with transmitting video.
Are you talking about the ribbon connector internal to the camera that runs from the lens board to the camera board? Or maybe the one from the camera board to the WiFi board?
I'm not sure we can help on this one, but if you can better describe what you need, it's a better chance at "maybe".
howbirds
