Typhoon H Bolt to secure top and bottom shells spec?
Does anyone know the specification for the 1cm long, socket head bolts that hold the top and bottom shells of the Typhoon H together? I suspect they are M2 X 10mm. Need to order some more online.
Thanks!
This is not metric thread nor other kind of screws for metal thread. It is some kind of Thread Forming Screws For Plastics with 1,5mm hexa drive. Sorry, I don't know the exact name or specification.
Ask YuneecSkins, maybe he can help
Reactions: Nesher
OK, then these (see link below) should work.
The screws mentioned above have a much broader and deeper thread pitch; therefore they probably work very well, but then you can't go back to the original.
So I'll try these, and let you all know.
M2 assortment on Amazon
UPDATE: The thread pitch on these is wrong. Just buy the correct ones from Yuneec Skins! Here's the link again:
Top Shell screws for Typhoon H
These are the proper screws. They are 2mmX7.8mm with a 1.5mm hex socket head. The thread is is much like a wood screw with a higher pitch and slightly deeper thread than a machine screw. With this threading into plastic I don’t think a machine screw is going to maintain the necessary structural integrity. It will strip out the plastic much easier.
That is why i recommended the 2m self tapping use them all the time on DJI and Yuneec
Reactions: DoomMeister
I agree with your choice. The major difference being the pointed end for self tapping. This is a good replacement in my opinion.
Machine screws work well in threaded metal, but the thread pitch is too fine for plastic and wood.
Some of the higher priced quads like DJI Inspire use metal threaded insert so I use the machine screws when required
Just a heads up. Screws like those are notorious for stripping out the plastic where they are used. Once removed, you should always clean / dust off the screw threads to get rid of the excess plastic, then when screwing them back in, carefully back them out until you feel a slight click. This is how I know I'm probably aligned with the original threads. If they go in hard the second time they are probably cross threaded and gouging out the mount.
Good point!!!
I do this with all types of screws. Just a habit I got into when I started working with fine thread machine screws in the intricate mechanical assemblies of circuit board manufacturing equipment.
As a journyman Tool and Die maker 40 years ago I learned to use bar soap as a simple lube on all threads that are not thread locked. Works well on these also. I agree allways go forward and backup a little befor next turn.
Reactions: Nesher
Thanks! Now, where do I buy them?
Patynowy
