Typhoon H GUI Compass Values
Winder , Georgia
I have a Typhoon H that has been placed near a large magnet.
I have performed the calibration and by all of Yuneec's led communication, the calibration was a success.
Call me OCD, I would love to know the proper compass value readings.
I am looking to connect to the Yuneec GUI and verify the telemetry in real time prior to lift off.
Have not found info regarding this question through the forum search method.
Posting here in the hopes that someone can give me the values that I should be looking for.
Thank Guys.
Just performed the compass calibration on my H480. I always face local Magnetic North when I do this.
My GUI Compass values with the aircraft level and pointing MagNorth are X:165, Y: -18, and Z:451. X changes with aircraft pitch, Y changes with yaw, Z and Y change with roll. Right above that is Orientation Roll reads -1.0, Pitch reads 1.3, and Yaw reads 0.2.
The compass IC is a 3 axis magnetometer and the values probably make no sense. As long as your Orientation is fairly close, especially the Yaw, you should be fine. The issues that arise would be when Yaw and the GPS are more than just a few degrees off.
Reactions: JMichael
sunwininstitute
