Typhoon H Issues
Ok, this one has me. Cant figure it out.
Typhoon H
Issue 1: CGO3 connects to ST-16 but no controls.
2: Re-Bind all and motors start without start up from controller but no camera
3: Controller reads No GPS, then found, then loses it.
All this happens at once, or in re-binding
Any ideas?
No Crashes, Hard Landings no abuse.
Cant figure it out, have check all ST-16 internals visibly have not found anything.
I'll be interested in this as I had to get new slip ring to reattach c23. Camera works but no controls. Seems to spin like it's lost its mine when it's bound. Maybe is there somewhere in h plus controller to calibrate camera motor? Not sure
I think the guy is confused. :rolleyes:If he doesn't know what camera he has and he's flying a drone:eek:, run.
I'm wondering if he read the manual? NOT! If he did he would know what camera he has!
Reactions: Phaedrus
Typhoon H Plus
Any ideas?
If you read this manual you'll know what equipment you possess.
  • Typhoon_H_Plus_Manualv0.5.pdf
I know exactly what I'm flying, just accidentally put Plus into the post.
So you were wishing you had an H+.;)
  • TYPHOON H USER MANUAL Vcho3-1.pdf
daps20
