Typhoon H plus blades on an H520?
UAS-USA
Has anybody tried using typhoon H plus blades on a 520 they’re $20 cheaper? Is there any difference ?
The Hplus and H520 propellers are the same. there are no differences. But if there is $ 20 difference, I do not know how much you have to pay for the H520. I feel a little scam here.
In France, they are 21.90 € the three Hplus or H520 is $ 24.62.
16065
From the dawn of power, Orange Paint has always been worth more... especially over Blue!
For those not gear heads... that's a Chevy Plug! o_O;)
Hmmmm....
Orange Hemi, adopted upon Chevy retire orange yes?
(More entertaining if pronounced as Yoda)
Orange, blue, yellow, black ... Mopar year’s they were?
It is like the H+ and 520 batteries, exact same cells, in different color cases and the 520 is $20 more. ?
I'm told by Yuneec UK that they are different. Certainly I know you can't use the same charger, I've tried. The H batteries have a lower power output but will work in the H520 and so the flight durations are less.
I'm told by Yuneec UK that they are different. Certainly I know you can't use the same charger, I've tried. The H520 batteries have a lower power output but will work in the H520 and so the flight durations are less.
I believe you are thinking of the H. The Packs and cells in the H PLUS and 520 are the same. THey are both 4S 5,250 mH LIHV cells/packs. They use the same charger and same charge connections.
The H is different..
Reactions: NorWiscPilot
Oscar, you might want to edit your post. You state H520 for both sides of your equation.
The H520 and H Plus batteries are the same, and both can use the same chargers. Example: DY5 will handle the H520 and H Plus LiPo HV (high voltage) packs.
It is the H480 (Typhoon H, H Pro) that used the LiPo batteries. These require a different charger. The DY3 is one that can.
The Yuneec supplier chargers are different between the H520/H Plus versus the H480 (H and H Pro).
Note: The H and H Pro are the same airframe. The options make the difference.
Also, the H480 batteries will work in the airframe of the H520 and H Plus. I believe I have read that the LiPo HV will work in the H480, but do not recall exactly, and I not have personally tried. Therefore I am staying away from stating that as fact.
Hope this helps.
Jeff
[Edit: @Phaedrus and I were composing our replies at the same time!]
Reactions: Phaedrus
Hope this helps.
Jeff
Apologies Phaedrus, simple typing error!
jonnyelectric
