- Joined
- Jul 14, 2020
- Messages
- 43
- Reaction score
- 13
- Age
- 68
You are a genius my friend. Followed your advice again (wise choice !) and it worked !!! Just came in from a test flight and so far...so good. After I swapped flight controllers, I recalibrated all. Was able to get GPS and start motors. Time for a test flight ! Took it out back and went up about 30 ft. There is about a 15 mph wind now where I am in Michigan and the H held steady. At first the landing gear would not go up, but after several flips of the switch they did work. The OAS still shows as unavailable; I have Realsense installed, but have never been brave enough to aim for a tree or building on purpose to test. Question: If Realsense is installed, does it replace the OAS (hence unavailable) or do OAS & Realsense work together?? Do you have any suggestions to safely test each system ?
Bye the way...you have saved me a lot of time, frustration, and money. I think the least I can do is buy you a nice steak dinner (or similar if you prefer something else). If you have my email, send me the name of a steakhouse near you so I can send you a gift card. Will also need address to send to. May have to wait to use if restaurants are closed by you like here. Please advise.
Thanks !! Dave
Thanks !! Dave
