Version N/A
My Typhoon is descending so slowly and landing weird i decided to upgrade firmware. (yes, i re calibrated)
I updated typhoon h firmware via WiFi and locally from sd card and it still is showing N/A for version. See pic.
I couldn't find any suggestions googling so thanks in advance for any help.
In addition to PatR's solution, you should check the ST16 sticks in Hardware Monitor to see if they are moving full scale. That may be your original problem.
That too.
The NA in autopilot and gimbal indicates the system is not recognizing the firmware. The refresh of the firmware and binding to it would correct that if the bind is successful. Having missed a bind myself in the past I know the H can act strangely if itms not connecting with the firmware.
If the system does not “see” the firmware after a refresh, put the ST-16 in Team mode and repeat the refresh. It should show up then if it was loaded properly.
ok9studio
