Video cut out
Dey
My typhoon g is new. 1st couple of flights reception for video was fine.
It now cuts out at about 60 to 80 ft distance and only reconnects when very close to the controller.
I've checked the connections and did what I could look at with the settings.
It works when close but is slow, jittery.
Then cuts out at 60 ft.
Any ideas. Thx.
Can you try connecting with your phone and cg03 app? See if you get some distance?
Trying to figure out if it is the camera or the controller.
In both cases you want to check the antenna. Difficult on the camera though...
Forgot to mention that camera is a gopro
I did connect with the phone go pro app but cuts out at same distance.
Any ideas. Thx.
Can a moderator move this thread to the "Typhoon G Discussion" forum?
Reactions: Forrestt
wiebeedigital
