Video Format
Hello All.
New Here and thanks for letting me join.
My question is, can the video format to record be changed from mp4 to something else?
Ive done a bit of recording, i can play back on the controller via micro sd card.
But if i put that same sd card into a different tablet, the vids will not play or am i just doing something wrong??
Me
You cannot change the recording format, no... However you can convert the .mp4 file to a different format with any number of 3rd party video converter programs out there.
Just in case you were using a Fire tablet, if you recorded in 4k the tablet can’t play it. Fire tablets are limited to a max of 1080p.
Thanks i didnt think it could be changed but i thought id check.
The tablet i have is just a cheaper rca viking pro 10.
I downloaded a converter.
Ill give that a spin and see whats happens
If you are shooting the original footage in 4K, you may need to downsize the footage to 1080p for them to play on your tablet... especially if that tablet does not have the computing power or video capability to process the amount of data in a 4K file. However continue to shoot in 4K... you will get better hardware down the road.
Thanks for the help dudes..
Got it figured.
Was in 4k, decreased to a smaller format.
Works like a charm..
Again, thank you tons
Al
Reactions: rdonson
aatechnology
