wanted dual charger for yuneec typhoon h3
looking to get my hand on the dy5 version that works with typhoon h3 batteries. for use with the h520e. h3 batteries are compatible with h520e just need the dual charger.
There are none at the moment
I will be modifying my base the same as we did 4 years ago for the original H480 batteries
when modifying the base the third party charge leads need to be soldered on the top side of the cube this time around and not the under side. when you open it up you may see why it easier to do it.
Dvca441772
