Why is the image yawed in “Sensor information “ when the drone is straight?
I have been noticing the drone will not yaw to the right when I move the left stick to the right. I connected the drone to the GUI and I noticed the image is yawed when the actual drone is straight
If you rotate the Q500 to the right (clockwise) does the image do so? 0 degrees should be Magnetic North.
Reactions: vmaxmasonrya
Actually Magnetic North. Set your phone’s compass to read Magnetic North and see if the aircraft is pointed that way when the sensor reads 0 degrees in yaw.
daps20
